Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > 600W Power Supply Enough?
Forum Homebuilt Systems : General Homebuilt - 600W Power Supply Enough?
Around December I built a computer for myself for gaming and what not.
Specs
Motherboard: MSI P6N SLI Platinum ATX Intel Motherboard
Graphics:XFX 8800GT 256MB
CPU: Intel Q6600 Quad Core
RAM: 4x 1G DDR2
FANS: 1 80mm 2 120mm All LED
HDD: 2 Sata HDD 1 External
Powersupply: 600w
The problem is now I want to SLI another 8800GT 256MB to it and I'm not sure if the 600w should cover it. Any ideas?
Sponsored Links
Not really, but I would not SLI those GPUs.
256MB 8800GTs are underpowered. The thing that is most holding up your gaming performance at this point is the 256MB. Adding a second card does not double your video memory.
In the SLI category, 9800 GTX is under $200 these days.
You would have to supply a great deal more information about your power supply, before I could say it was ready for SLI.
It has a label on it, or should, that will give all the info.
Reply to Proximon
@OP: What PSU(brand) are you running? Imo, I too wouldn't SLI 8800GT 256MB as those cards are VERY limited by the RAM.
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
Evga recommends a 450W PSU with +12 Volt current rating of 30 Amps for a 8800GT KO 512mb SLI setup.
Unless you have a real dog of a budget PSU you should be OK.
If you're using a 1280x1024 resolution monitor the SLI 8800GT 256 might work out ok.
But as Proximon suggests you'll have to look hard at the SLI vs better card upgrade option.
Reply to WR2
There are 1150 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
