According to the specification, your PSU has four 12V+ rails, each of them capable of up to 18A, although the total on all of them is limited to 52A (rather than 4x18 which would be 72A). If your PSU is of sufficient quality (not sure about Hiper, was only tier-4 on an old list), you should have no problems at all.
------------------------------There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
Yes, they ask 28a COMBINED. This psu has 4 rails of 18A = 72 (if it works like that). The wattage is enough and you have 2 pci-e 6 pin connectors and 1 pci-e 8 pin connector and you need 1 of each so you are fine.
I think that Hiper model is a bit better than the same company used to do in the past, so that means that you should be just fine with that.
With the hardware you've got, a solid-quality 400w unit would've been fine. The Hiper isn't a gold-standard PSU, but at 680w it should be plenty sufficient.
