Tom's Hardware > Forum > Homebuilt Systems > New System Build > building my first system
Forum Homebuilt Systems : New System Build - building my first system
hey all, I was thinking about building a sub-$1000 and was wondering what you guys thought of it.
SAMSUNG 20X DVD±R DVD Burner with LightScribe Black SATA Model SH-S203N - OEM
Model #:SH-S203N - $26.99
COOLER MASTER Centurion 5 CAC-T05-WW Black/Silver Aluminum Bezel, SECC Chassis ATX Mid Tower Computer Case - $59.99
Western Digital Raptor X WD1500AHFD 150GB 10000 RPM SATA 1.5Gb/s Hard Drive $174.99
MSI K9N SLI-F V.2 AM2+/AM2 NVIDIA nForce 570LT ATX AMD Motherboard $79.99
2x EVGA 512-P3-N802-AR GeForce 8800GT Superclocked 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - $311.98
Rosewill RP550V2-D-SL 550W SLI Ready-ATX12V V2.01 Dual Fans Power Supply - $59.99
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ - $79.99
AMD Phenom 9850 2.5GHz Socket AM2+ 125W Quad-Core Processor Model HD9850XAJ4BGH - $209.99
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - $26.99
total: ~$1030
I'll also need a few case fans and some thermal grease, but I'd rather focus on components first.
Thanks
Sponsored Links
What are the uses? Will the cpu be overclocked?
Reply to akhilles
That's a lot of money to spend on a hard drive. You can get a much bigger drive for less, which will be almost as fast. Use a portion of the money saved there to buy a better quality PSU. Some Rosewills have received a favorable review by Jonnyguru, but a) I'm not sure that's one of them, b) the brand as a whole appears on tier-5 ("Do not buy" ) of an admittedly aging PSU listing, and c) cheap / bad PSUs tend to smoke and croak at some percentage of their claimed rating, often taking other parts with them.
Corsair, Antec, Enermax, PC Power & Cooling, and OCZ all make good PSUs that would be better choices.
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
Check these hard disk's charts for a speedy one with good capacity:
http://www.tomshardware.com/charts [...] e,658.html
Reply to evongugg
There are 856 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
