So I recently got fed up with my old heatsink: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103041 , and since there was a great sale on the Sunbeam Core Contact Freezer at newegg I bought it. However since switching coolers my temperature has gone UP. from about 33idle/42load for the core temp and 45idle/55load for the CPU temp on the old cooler, to 40/50 core and 55/65cpu.
The system is a Kuma 7750 on a ASRock 780FullHD board. I've tried resetting the heatsink twice with different amounts of thermal paste (both Artic Colling MX-2 and Tuniq TX-2) but nothing seems to work. It's not case airflow, since the temps only change 1-2* between having the side panel on or off, and wierdly the top of the heatsink is barely warm, while the bottom seems hot, but not crazy hot.
It's in a small case (GMC Carona) but there's about 2" between the fan and the wall infront of it, and it exhausts 3" in front of the exhaust fans. Also, the fan spins at the correct speed, 1-2k depending on the controller according to Speedfan.
At this point I'm just lost as to why this could be happening. The new heatsink is one of the best according to frostytech, how could it cool so much worse than the little coolermaster piece of junk it replaced? Any help would be greatly appriciated.
