Removing Unused Fonts
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I have more fonts than I actually need with my use confined to a dozen or
so. How do I go about removing the un-needed ones?
6 answers Last reply
More about removing unused fonts
  1. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    How To Install or Remove a Font in Windows
    http://support.microsoft.com/default.aspx?scid=kb;en-us;314960
    Carey Frisch
    Microsoft MVP
    Windows XP - Shell/User
    Microsoft Newsgroups
  2. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Hi Bob,
    There is no reason to remove unused fonts (C:\Windows\Fonts), they do not
    load into memory at boot nor do they take all that much space. To remove
    one, simply click on it and delete it, but be aware that some fonts are used
    by the system and should not be removed.
    Best of Luck,
    Rick Rogers, aka "Nutcase" - Microsoft MVP
    http://mvp.support.microsoft.com/
    Associate Expert - WindowsXP Expert Zone
    www.microsoft.com/windowsxp/expertzone
    Windows help - www.rickrogers.org
    "Bob Davis" <rjdjr@mindspring.com> wrote in message
    news:_p2Qe.3155$FW1.1695@newsread3.news.atl.earthlink.net...
  3. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    > dozen or so. How do I go about removing the un-needed ones?
    Just select the font you don't want and press delete.
    However, be extremely careful. Even if *you* don't use a particular font,
    Windows may use it, and deleting it will get you into trouble. Don't delete
    anything unless you're *sure* it's not a system font.
    Ken Blake
    Please Reply to the Newsgroup
  4. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Thanks.
    "Carey Frisch [MVP]" <cnfrisch@nospamgmail.com> wrote in message
    news:%23vS2OfzqFHA.1132@TK2MSFTNGP10.phx.gbl...
    > Carey Frisch
    > Microsoft MVP
    > or
  5. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    I get a extremely long list of choices whenever I want to make a font
    change. I prefer verdana for most of my documents and currently I'm on the
    kick of using comic sans ms for OE. How do you identify fonts the system
    uses? Thanks.
    PS: I'm looking at the KB article suggested by Carey Frisch right now.
    "Rick "Nutcase" Rogers" <rick@mvps.org> wrote in message
    news:OuoCEhzqFHA.2604@TK2MSFTNGP14.phx.gbl...
    > Hi Bob,
    > used by the system and should not be removed.
    > Best of Luck,
  6. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Fonts supplied with Windows XP
    http://www.microsoft.com/typography/fonts/winxp.htm?fname=%20&fsize=
    Carey Frisch
    Microsoft MVP
    | uses? Thanks.
Microsoft Windows XP
