New Build Problems
Hi All,
I just finish building a new PC.
I had to restore windows 7 home prenium 64 bit twice now because after restarting (I didn't even installed something between the restarts) it said windows could not load and ran a repair sequeence and could not find anything. But when I restore windows 7 to the earliest point (with out any drivers installed) seems to work.
What do I NEED to install from drivers list for my MOBO? http://ca.asus.com/en/Motherboards/Intel_Socket_1155/P8P67_PRO_REV_31/#download
because when I try to install this:
Intel(R) Rapid Storage Technology Driver Software V10.5.0.1026 for Windows Vista/7 32bit & 64bit.(WHQL)
I get a bluescreen of death and PC restarts
Here is my built:
HDD: http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136795
RAM: http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231445
Videocard: http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130587
MOBO: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131771
CPU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115072
PSU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16817182188
CASE: http://www.newegg.ca/Product/Product.aspx?Item=N82E16811147153
2 answers Last reply
More about build problems
  1. you dont need the Rapid Storage Technology Driver Software unless you really wanted a matrix raid. im betting you just wanted all your stuff on a single hard drive.
    heres a full description of it.
    http://www.intel.com/support/chipsets/imsm/sb/CS-020784.htm
    just skip it.
    a bios update might fix it but i doubt it since its not listed in the notes.
  2. k thanks that's what I thought...
    Do i need these though ? i think I do right ?
    JMicron JMB36X Controller Driver
Windows 7 New Build
