Tom's Hardware > Forum > Home Theatre > Digital TV > How to connect analog RF cable to TV with HDTV tuner
Forum Home Theatre : Digital TV - How to connect analog RF cable to TV with HDTV tuner
Archived from groups: alt.video.digital-tv (More info?)
Hi all,
I just bought the following TV - Panasonic PT-60LCX63 and need some
help....
http://catalog2.panasonic.com/weba [...] Redirect=1
The TV has the following tuners:
- NTSC tuner (Standard analog broadcasts)
- ATSC/QAM tuner (SDTV and HDTV broadcasts)
I just have analog cable at home (TVMAX).
At the back of the TV, there are two antenna RF inputs (A and B).
Input A is labeled 'Cable In'.
The instructions say to always connect the cable to A. Only if you
have both (antenna and cable, use A and B).
BUT:
When I connect the RF cable to A, the channel search doesn't find
anything.
When I connect the RF cable to B, all channels are found.
The instruction doesn't say so, but is it possible that input A is
just for digital cable and doesn't accept an analog connection ?
Or should a digital connection be downward compatible with an analog
connection ?
I really don't know what to do. I called the Panasonic support and
they told me there 'MIGHT' be a problem, but they don't know exactly.
I should ask a local dealer. But they also didn't know....
I would like to know if input jack A is broken or really only can be
used for a digital connection.
I normally wouldn't mind to us B, but I just need to know what's
wrong...
Maybe someone is kind enough to look at the manual and tell me what to
do.
The manual can be found here:
http://service.us.panasonic.com/op [...] 0lcx63.pdf
Any help is appreciated !
Thank you very much,
Dan.
Sponsored Links
"Jan" <sesselmarder@yahoo.de> wrote in message
news:3ce05b23.0405182037.dfb9ac0@posting.google.com...
< snip >
> BUT:
> anything.
Check page 27 of the manual. I think your just scanning the B input. You
can hook up to A, but if you don't scan it, you'll get nothing, since your
really scanning B all the time. Try it
Not likely, also per page 27. I think both antenna inputs feed an
all-channel analog tuner, but you can only do QAM on antenna (A). This is a
guess and since you don't have digital cable, there's no way to test the
theory. At any rate, see page 10 of the manual and see the buttons marked
Item 20. You should be able to toggle between the two antenna inputs. If,
when you select A you lose signals since you're connected to B, you should
be able to go behind the set, move the input connection to A and have your
signals back. Try it.
Tell me approximately where you live and I'll tell you whether you have any
over-the-air ATSC service nearby. It'll be interesting to see if you can
receive ATSC on either or both antenna inputs.
"Sal"
Reply to Anonymous
There are 720 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 demondrumer won the Freshman badge
  • 01:00 tehue won the Freshman badge
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
