Hey guys,
I'm totally new here and to building PCs. But here I am jumping in at the deep end.
I've got a max. budget of £850, but I would prefer to keep this closer to £700 if possible. I picked out almost all the components from reviews and a few suggestions on NBR, I'd greatly appretiate it if anyone could recommend better parts, compatibility issues or advice in general.
So here's the list:
MOBO: Gigabyte GA-EP35-DS3R Intel P35 (Socket 775) PCI-Express DDR3 http://www.overclockers.co.uk/showproduct.php?prodid=MB-135-GI
CPU: Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB) http://www.overclockers.co.uk/showproduct.php?prodid=CP-161-IN
CPU Cooler: Thermalright Ultra-120 Extreme http://www.cclonline.com/product-info.asp?id=22763
GPU: BFG GeForce 8800 GT OC2 512MB GDDR3 http://www.overclockers.co.uk/showproduct.php?prodid=GX-053-BG
GPU Cooler: Thermalright HR-03-GT VGA Cooler http://www.overclockers.co.uk/showproduct.php?prodid=HS-053-TR
RAM: OCZ 2GB Kit (2x1GB) DDR2 800MHz/PC2-6400 CL 4-4-4-15 PLATINUM XTC with LIFETIME WARRANTY http://www.ebuyer.com/product/116755
HDD: Western Digital Caviar SE16 640GB Hard Drive http://www.cclonline.com/product-info.asp?id=22025
PSU: OCZ 600 Watt Game X Stream PSU http://www.cclonline.com/product-info.asp?id=7330
Case: Antec Nine Hundred Ultimate Gaming Case http://www.overclockers.co.uk/showproduct.php?prodid=CA-065-AN
Optical Drive: LiteOn LH-20A1L-14C 20X DVD±RW DL & RAM 20x20x12 SATA LightScribe Black - Retail http://www.ebuyer.com/product/141995
Monitor: LG L207WT 20 inch Widescreen LCD TFT Monitor http://www.cclonline.com/product-info.asp?id=19960
OS: Vista Home Premium 64bit £59.18
That is pretty much it. Only thing I'm disappointed about is that I couldn't find the XIGMATEK HDT-S1283 w/ retention bracket so I had to settle for the Thermalright.
I'm planning on overclocking the CPU and the GPU, is there anything else I should add?
Thanks
So here's the list:
Thanks
