Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > New power supply troubles
Forum Homebuilt Systems : General Homebuilt - New power supply troubles
I recently bought a new power supply for my computer because I was tired of the horrible cable problems I had with the old one. I got the Zalman ZM600-HP, because of the great reviews I read about it. I put it in, plugged everything in, and attempted to turn it on. Unfortunately, there is not a hint of activity when I press the power button. The motherboard LED does light up when I plug the PSU in, but that is as far as the response goes. I tried making contact with a screwdriver between the two motherboard pins that the power button plugs into, but still no response. Is it possibly that the PSU is DOA, or does the motherboard LED indicate that it's still working? Any ideas/suggestions?
Thanks!
Sponsored Links
Is the 24 pin and 4pin plugged in fully?
Reply to Shadowthor
Yeah I checked that. The PSU has a 20 pin connector with a 4 pin directly alongside, and the diagram said just to plug them both into the 24 pin motherboard socket. It also has two 4-pin CPU power connectors, so I just plugged one in. I'm not really sure why it had two.
Reply to ReverendGadgetBoy
If you have an 8 pin connector on your mobo, then you need both 4pins there. That may be a problem if yer cpu is not getting the power it needs. Also, check your cables for your power button and all those from the front of the case. You may have knocked one loose, or put it back in the wrong spot. I had this problem when i built my computer because the colors on the board did not match the colors from the case. I think yer PSU is fine if yer mobo lights up. Just check all the connections inside, its possible you knocked another connection loose somewhere.
------------------------------ Intel Q6600 @ 3.0 GHz, Artic Cooling Freezer Pro 7, NZXT Apollo, OCZ GameXStream 850W PSU, 8800GTS 512 SLI, XFX 680i LT SLI, 4 GB OCZ SLI 5-5-5-15-2T, Seagate Barracuda 250 GB, WD 640 GB, Windows 7 Pro 64
Reply to billin30
I think I only have the 4 pin connector on the mobo, because my old PSU only had a 4pin and it worked great. I certainly don't see another place to plug a 4-pin in. I did recheck the power button cables, they seemed to be connected, but I also tried directly connecting the pins on the motherboard in case the button was broken. No dice.
There are 1048 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
