I have gotten lots of comments on my old build and how un-efficient it was so i diecided to take some advice and do this i do know that i want the GTX260 and a http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137 as a case because it is a great company and a great case! so lets see what yall can come up with!
HERE IS MY LATES BUILD !!!!
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail
Seagate Barracuda 7200.10 ST3250410AS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148262
SAPPHIRE 100242L Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102747
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V Power Supply 100 - 240 V UL, CE, CB, TUV, FCC, CCC - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
Arctic Silver 5 Thermal Compound - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
mushkin 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146764
Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
I know there is no mobo but i do need help with that!! so plz gimme some suggestions
If you can build a kickass system with the HD4850 (excuse my language) I am now open to the fact of ATI cards again...
