Tom's Hardware > Forum > Wireless Networking > Setup, Configuration & Security > [Solved] How to set up wireless and keep hard-wired connection d/l speed
Forum Wireless Networking : Setup, Configuration & Security - [Solved] How to set up wireless and keep hard-wired connection d/l speed
Best answer from lyleb.
Hello folks,
I want to create a wireless internet connection so that I can access the internet with my laptop anywhere in my apartment. I have a 15 Mb/s high speed internet connection that runs through a Motorola Surfboard(r) modem that is connected to my desktop via an ethernet cable. I'd like to keep the fast speed of this hard-wired connection and do what I can to also make the same signal wireless.
Is this as easy as just buying a wireless router? I'd like to make the addition of creating this hotspot as simple as possible. Can anyone make a suggestion on how to do this?
yours,
-Eric
Message edited by MassivePepper on 08-21-2009 at 03:54:13 AM
------------------------------ Intel 5200 2.5 GHz/ Gigabyte GA-G31M-ES2L/ Corsair 2x 2GB DDR2 800/ Radeon HD 3870 512 MB 256-bit/ Sunbeam 120 mm CR-CCTF HSF/ WD Caviar Black 640 HD/ Antec BP430 PSU/ Antec 300 case
Just add a wireless router to you network.
You may need to bridge your modem. Check with your ISP on that.
I would recommend purchasing an "N" router.
Download the router users manual for instructions.
Sponsored Links
Also, the wireless speed doesn't have to be quite so fast, as I hope to use my desktop for downloading large files, or any heavy bandwidth taxing issues.
Thanks.
Reply to MassivePepper
anyone?
Best answer
Reply to lyleb
Lyleb,
I thought that indeed this was the case and I'll inquire further at the store (Staples) to see what I need.
Based on preliminary researching it seems I'd probably do well with a G router because I think that is what my year old laptop is most compatible with--I'm connected to a wireless connection now that is broadcasting a G-signal. Since road runner turbo only gives me up to 15 Mb/s a G ought to suit me nicely if not become obsolete faster.
Thank you for the reply! I hope I can award you best answer.
Do you think that a N router would deliver better results?
I attached a G-router and am having terrific reception with my laptop, but the desktop hardwired to the router has a real tough time loading pages correctly, though speedtest.net shows a blazing fast speed.
Right now I'm switching the cords in and out so that I can maintain best speeds and effectiveness though I'll run into problems if I want to use both at the same time.
There are 1119 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
