Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Air Cooling for a GA-MA790XT-UD4P in a Antec Sonata Case
Forum Overclocking : Cooler and Heatsinks - Air Cooling for a GA-MA790XT-UD4P in a Antec Sonata Case
Im looking to upgrade my system since my current MB seems to be on its last leg. I'm going with AMD this time and Im looking for a good Air Cooler that will fit my case and new board.
This is what Im looking at for the upgrade
CORSAIR TW3X4G1333C9 4GB (2x2GB) PC3-10666 (DDR3-1333) DDR3 10010088 GIGABYTE GA-MA790XT-UD4P
AMD HDZ955FBGIBOX Phenom II x4, Black Edition 3.2Ghz
I dont plan on upgrading my Case which is a Antec Sonata I.
Any suggestions would be greatly appreciated.
------------------------------ Intel Core2 Duo E6600
ASUS P5W DH DELUXE
Corsair 8GB DDR2-800 XMS2-6400
ATI 4870
Sponsored Links
If your not going to overclock then this will work for you
http://www.newegg.com/Product/Prod [...] 6835200036
Are you going to be upgrading your video card? Reason I ask, Sonata's are great cases but they don't have enough cooling to handle today's video cards. So you might invest in a slot cooler to help. 120mm tower heatsinks more then likely, will not fit in that case. So you need to stick with a 92mm hsf.
Message edited by dkev on 09-05-2009 at 06:43:44 PM
Reply to dkev
I was thinking of doing a little overclocking. Im not going to update my video card, my signature is a little old. I upgraded my card a few months ago with a ATI 4870.
Im currently not overclocking so I never paid any attention to the temps. Im currently using a stock cpu fan.
ASUS P5W DH DELUXE
ATI 4870
Reply to whataboutbob
- 0 +
Ok you might go with this then
http://www.newegg.com/Product/Prod [...] 6835103057
It is a little pricey, but it should have no problem handling what you have in mind.
Reply to dkev
^lol, why pay that much when you can get this: http://www.newegg.com/Product/Prod [...] 6835207004
$25 after MIR. And yes, AM2 cooler will work with AM3 socket.
Here's a review: http://www.frostytech.com/top5heatsinks.cfm
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
- 0 +
Because a 120 tower hsf wont fit in his case. :ange:
Reply to dkev
Damn it! For some reason I read it as a Antec 900 :lol:
There are 873 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
