Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Good forums for water cooling
Forum Overclocking : Cooler and Heatsinks - Good forums for water cooling
In one of the replies to my thread asking about water cooling, someone posted links to a couple of forums that were recommended. I can't find the post. Can anyone recommend a couple of good water cooling forums?
Also, When I click on "my threads", it only shows a couple. I have posted much more than that. Is it not working? Also, is there any way to search the forums? The search on the top of the site does not return anything when I search for my log in name.
Thanks.
Sponsored Links
Here you go:
http://www.tomshardware.com/forum/ [...] ling-guide
The links are listed under "Forums". Unfortunately, half the links aren't working due to a bug in the Toms website. The links under the "Forum" are working tho.
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
Thanks.
I believe i was following your post even when you went over to www.ocforums.com . Which is one of the better forums for water cooling.
Reply to AGirlsBuild
------------------------------ antec p180
gigabyte GA-MA785G-UD3H
Phenom II X3 720 BE @ 3.5
g-skill ddr 1066
Reply to pont
www.dangerden.com works well to
g-skill ddr 1066
Reply to pont
+1 for OCForum. Im there under the same name. So is Conumdrum,et al.
There are 998 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
