News
ASRock Creates New Motherboards Out Of Old Parts
Published on December 06, 2007
ASRock's latest AliveDual eSATA2 motherboard combines the M1695 chipset, originally designed by ULi, with Nvidia's nForce 3 250, which launched in 2003, to create a modern mash-up that may sound bizarre, but is also strangely compelling. Read more
Thermaltake unveils Spirit RS heatpipe memory cooler
Published on January 16, 2007
Thermaltake has launched its new Spirit RS RAM cooler with heatpipe. The Spirit RS heatsink is separated into two parts for improved performance and compatibility. Read more
No defects in PS3 stamping parts, says maker
Published on November 21, 2006
Taiwan-based G-Shank Enterprise stated that stamping parts it manufactured for Sony's PlayStation 3 (PS3) game consoles have no defects and should not cause malfunction of the console's card reader, according to a November 20 filing the company made with the Taiwan Stock Exchange (TSE). Read more
CES 2007: CarMD finds the problem, then tells you what parts and labor should cost
Published on January 09, 2007
Two crappy things in this world: (1) Your car breaking down and you not knowing why; and (2) going to get it fixed and being charged an arm, a leg and some other essential regions in order to get it fixed. Read more
Latest Reviews & Articles
System Builder Marathon: Performance & Value
Published on October 31, 2008
Three dramatically different builds face off in a show of performance, defining the real value of each. Our mainstream system is designed to meet the needs of most users. Who should spend more and who can live with less? Read more
System Builder Marathon: $500 Gaming PC
Published on October 30, 2008
For the second to last day of our System Builder Marathon series, we add a $500 gaming PC to the mix. It's not going to be as quick as our other two builds, but we think Paul was able to get some serious value from this thing. Read more
Tom's SBM: The $1,500 Mainstream PC
Published on October 29, 2008
We're following up yesterday's $4,500 behemoth with a more affordable $1,500 mid-range build. Let's see what sort of performance (and overclocking headroom) you can get when you spend one third of the money. Read more
System Builder Marathon: The $4,500 Super PC
Published on October 28, 2008
This month's System Builder Marathon spreads the system prices out even further to $4,500, $1,500, and $500. Is today’s $4,500 system really worth three times as much as an upper-mainstream performance machine? Read more
  Tom's Hardware Forums » CPU & Components » CPUs » Looking for confirmation on compatibility of parts.
Word :   Username :
Bottom
Author
 Thread : Looking for confirmation on compatibility of parts.
Profile: stranger
More Information
I'm building my first computer and I was wondering if these parts would all be compatible together. I don't think there's any problem other than the space regarding the graphics cards. Here's the parts I've chosen.
Case:
LIAN LI PC-B25B Black Aluminum ATX Mid Tower Computer Case - Retail
Item #: N82E16811112148 - http://www.newegg.com/Product/Prod [...] 6811112148
CD/DVD Driver:
ASUS 20X DVD±R DVD Burner with LightScribe Black SATA Model DRW-2014L1T - Retail
Item #: N82E16827135156 - http://www.newegg.com/Product/Prod [...] 6827135156
Hard Drive:
Western Digital VelociRaptor WD3000GLFS 300GB 10000 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: N82E16822136260 - http://www.newegg.com/Product/Prod [...] 6822136260
Graphics Card(s):
2 x EVGA 512-P3-N874-AR GeForce 9800 GTX+ Superclocked Edition 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
Item #: N82E16814130385 - http://www.newegg.com/Product/Prod [...] 6814130385
Sound Card:
Creative Sound Blaster X-Fi XtremeGamer 7.1 Channels PCI Interface Sound Card - Retail
Item #: N82E16829102006 - http://www.newegg.com/Product/Prod [...] 6829102006
Power Supply:
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
Item #: N82E16817139006 - http://www.newegg.com/Product/Prod [...] 6817139006
Memory:
OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model OCZ2RPR10664GK - Retail
Item #: N82E16820227289 - http://www.newegg.com/Product/Prod [...] 6820227289
Motherboard:
EVGA 123-YW-E175-A1 LGA 775 NVIDIA nForce 750i FTW SLI ATX Intel Motherboard - Retail
Item #: N82E16813188026 - http://www.newegg.com/Product/Prod [...] 6813188026
Processor:
Intel Core 2 Duo E8600 Wolfdale 3.33GHz LGA 775 65W Dual-Core Processor Model BX80570E8600 - Retail
Item #: N82E16819115054 - http://www.newegg.com/Product/Prod [...] 6819115054
My main concern was whether or not I could fit two 9800 GTX+'s on the 750i without having to sacrifice anything. And then I was wondering if that would fit in the case I've chosen. I've searched quite a bit for an answer to this question, but I haven't had much luck. If you've read this far into my post, I appreciate your time.
Thanks, Bc.
Related Product
Profile: Honorary Poster
More Information
Case:
CD/DVD Driver:
Hard Drive:
Graphics Card(s):
Sound Card:
Power Supply:
Memory:
Motherboard:
Processor:
Thanks, Bc.
The motherboard is an NVIDIA SLi board, so it is specifically designed to handle to NVIDIA GPUs like the 9800 GTX+s you selected. I'm betting the case will be a tight fit with two full-length GPUs like the 9800 GTX+s with the HDD bay placed where it is. You might want a slightly bigger case like the Antec Nine Hundred to fit two full-length cards. I have the Nine Hundred and it will fit very long GPUs easily, whereas my Cooler Master case that's roughly the size of the Lian Li you put there is pretty tight with a full-length GPU.
The rest looks really nice. It ought to be a really nice setup. Just don't forget to add an OS to that list and you'll be good go go.
UNIX is user-friendly- it's just picky who its friends are.
DRM is slowly killing personal computing, one Sony rootkit and TPM chip at a time.
Profile: stranger
More Information
Yeah.. Windows Vista Ultimate SP1 32-bit comes in a bundle with one of the products, so I think I'm going to go with that. Thanks for such a quick response. Very helpful. How tight of a fit would it be and would it be that bad for the computer? I spent a lot of time trying to decide on a case and I feel like now that I've finally chosen one, It'd be hard to find another that suits me as well. :/
Edit:
Assuming this is the case you're referring to:
http://www.newegg.com/Product/Prod [...] %20Hundred
I was comparing the sizes of it to the one I previously listed and here's what I get:
Antec Nine Hundred:
Width: 8.1"
Height: 18.4"
Depth: 19.4"
Lian-Li B25B
Width: 8.27"
Height: 17.72"
Depth: 20.28"
Assuming it's the height that you were saying may cause it to be a tight fit, would 17.72" vs. 18.4" make that much of a difference? Thanks again for your help.
Message edited by bchill on 10-03-2008 at 04:35:57 AM
Profile: journeyman
More Information
With only 2 drives (hdd, dvd) and only a PCI soundcard to consider re fit cables on the mobo itself, you are looking at winding a cable to connect point A to B for the hdd, and the pci-Sound is going to probably be well away from the vidcards.
The only problem I can see is air flow between the sound and vidcards, and I doubt soundcard is an issue. Assuming the board is MADE FOR SLI, you will likely be good to go.
I thought the case measurements were a good consideration; but it seems your case is very close to the other recommended case, in fact wider, so even more clearance re dvdrw approaching mobo, and routing cables = n/p
Be sure to air flow.
Do it. :)
Message quoted 1 times
Message edited by sighQ2 on 10-03-2008 at 06:45:49 AM
Profile: stranger
More Information
Do it. :)
This is exactly what I was hoping to hear, and yeah.. the board is made for SLI. Thanks a lot for the quick responses. This seems to be one of the nicer forums I've been to, so you'll probably be seeing me around more often. I'll post pictures of the spacing between the HDD and Graphics Cards when I build it for anyone who may be interested in doing a similar setup.
Thanks again, Bc.
Google Ads
