Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Need some CPU cooling advice (Q6600)
Forum Overclocking : Cooler and Heatsinks - Need some CPU cooling advice (Q6600)
Hi Everyone,
Essentially I am using a Q6600 in an Antec 900 case - my current CPU cooler is the Artic Cooling Freezer 7, which is great for cooling but is incredibly loud - has a horrible humming noise and is by far the loudest thing in my computer.
Anyone have any suggestions on what extremely quiet CPU coolers there are available for LGA775 sockets at the moment? If possible could you tell me how good they would be at cooling as well as how quiet they are?
Thanks for any info!
Sponsored Links
Have you tried tightening the clips that hold the fan against the fins?
You can slip some cardboard or anything in between the fan and the clip or the fan and the fins that would "make the fan thicker" and force the clips to hold it tighter.
is your BIOS set to run the fan at 100%? Or to control it vs vs cpu temp?
Reply to Twoboxer
Well ill tell you that i updated my artic freezer 7 to the next series up, artic freezer Extreme and it quiet as hell and provides 160W or cooling performance to my cpu.
Reply to bensheriff
it is on 100% yes - this is only because when i turn it down I hear the vibrations instead of the airflow (airflow imo is the lesser of two evils)
The clips are quite lose at the moment, didn't even think about tightening them. Will try that when i get back see if it helps
Also thanks bensheriff - is it about the same size? and a lot quieter?
Reply to visorneon
Ill link you , to me about about the same size about 1 inch bigger tho maybe, but is a hell of alot more cooler and effient and quieter than the last rubber banded artic freezer 7
link - http://www.arctic-cooling.com/cata [...] 42&mID=245
Reply to bensheriff
There are 1162 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
