Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Catalyst A.I Problems with Crossfire
Forum Graphic & Displays : Graphics Cards - Catalyst A.I Problems with Crossfire
I have two HD4870s in Crossfire, and I seem to be having problems with Catalyst A.I on both 8.6 & 8.7 drivers.
Now it tells me to keep AI settings in standard not advancded when using Crossfire, so of course I do that.
But when I have it in standard all my games have texture problems, it just seems the textures have not loaded(Its as if I have all game settings set to very very low texture wise, everything is blurred if you get me). Its in all games I play so obviously its the cards and very annoying. So I set A.I to disabled and then the games load the textures fine, but then I get performace issues I seem to get lag in some games I know I really shouldnt, and when using 3Dmark '06 I go from 18,000 when on catayst standard to 14,500 when A.I is disabled.
I'm just wondering is this a well known error, or is it just me.
Any help would be great.
thanks...
(oh and I've tried 8.6 and 8.7 drivers, so its not that)
Sponsored Links
From another forum:
Disable Crossfire in CCC Panel and see if it still does it.
If it doesnt, then its the Crossfire having a heart attack due to the older chipset and restrictions. I went from a P965 to a X48-DS4 with 3870's (and then with 4870's) and the difference was huge.
Crysis plays 1920*1200 at Very High DX10 vista at about 23-27FPS but HIGH manages 35-40fps with Crossfire Enabled with x4870's on a X48-DS4, with the P965 you are better off with ONE and not Crossfire thats for sure IMO.
http://forums.overclockers.com.au/ [...] ?p=9218813
Reply to georgy
Well I have a P45 board, and a 1000w PSU so I dont think thats the problem.
Reply to shaneire
afaik, disabling catalyst A.I, disables crossfire, when using crossfire, i believe you have to have it set to advanced. however, i am not sure what happens with the x2 as i have not bought one yet.
------------------------------ I'm a git, deal with it.
Antec 1200,PC Power & Cooling 750,Gigabyte DS4-x48,Intel Q9550@3.4 W/Xigmatek S1283,8GB OCZ DDR2 800,ATI 4870X2,X-FI>CA 640C amp>Tannoy R300/Senn 595's
Reply to strangestranger
There are 891 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
