Will this power supply be enough?
Hi everyone :hello:
I am going to build a new PC for myself. It will be my first time building one from scratch. Right now I have a general idea as to what I want in it. My question is this, if I have the following components in it...
MOBO- P43Twins1600 LGA 775 Intel P43 ATX Intel
CPU- Quad Q6600 2.4GHz and Heat sink/Fan
GPU-GeForce 8800GT 512MB
HDD- 500GB SATA
OPTICAL DRIVE-DVD-RW
CASE- Antec 900 with (1)200mm Fan and (2)120mm Fans
...will a 650W PSU be enough or do I need something stronger. The one I was looking at is this http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005 or something similar.
Thank you
1 answer Last reply
More about will power supply enough
  1. Yes it will provide plenty of power, and I was just going to recommend that exact model (Corsair 650W) .
Power Supplies Components Product
