Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Need advice about fans..
Forum Overclocking : Cooler and Heatsinks - Need advice about fans..
Today i finally received my new computer parts i got the Antec Three Hundred case and i was studying it and i saw that there's room for 2x 120mm fans in the front of the PC so what is the best coolers i can put there?..
The only requirements i have is that they are noiseless around 20db i think is okay and the price shouldn't be too high..
Also i'll need another fan for my CPU it's a AMD Phenom II X4 955 3,2Ghz - what would you recommend? a friend of mine says that the OCZ Vendetta 2 is a good choice..
Oh and one thing more.. i also bought a Accelero S1 Rev. 2 cooler for my new GFX which is a XFX Radeon HD4890XXX.. but im kinda afraid that it won't fit correctly on Arctic Cooling's homepage it says it fits for the 4870 card but i don't if there's a diffrence in size etc between the 4890 and 4870..
Message edited by jexter on 09-09-2009 at 08:41:57 PM
Sponsored Links
Actualy, this cas ehas room for three optional fans:
Antec 300 Cooling System:
• 1 rear 120 x 25 mm TriCool™ Fan with 3-speed switch control.
• 1 top special 140 x 25 mm TriCool™ Fan with 3-speed switch control
• 2 front (optional) 120 mm fans to cool the hard drives
• 1 side (Optional) 120 x 25 mm Fan to cool graphic car
http://www.antec.com/Believe_it/product.php?id=ODI5
http://www.newegg.com/Product/Prod [...] 6835209011
Reply to JackNaylorPE
If you are interested in quiet case fans, then take a look at some of the reviews and charts over at silentpcreview.com:
http://www.silentpcreview.com/
Reply to JohnnyLucky
- 0 +
Nice thanks :) but does anyone know if the Accelero Cooler fill fit the GFX Card?
Reply to jexter
I dunno off the top of my head. But ya know, might try this question in the video card forum too. A new header.
Noiseless fans with decent air flow which you will need? Dunno about that, but there are some good choices at silentPC. Ohh the stock fans are actaully not that bad, you can adjust the fans.
Only your final temps you get and your acceptable noise levels will decide if you need more fans.
A low speed side fan helps a lot on this air cooled case.
Reply to Conumdrum
There are 914 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
