News
ATI Catalyst Drivers v4.7
ATI released a new version of their Catalyst video card drivers. Read more
64-bit Pentium 4 brings power management to the desktop
Although not officially announced, Intel officials discussed the upcoming Pentium 64-bit 6xx-series during the ISSCC 2005. The corresponding Xeon MP platform will debut as single-core processor and receive a dual-core update later this year. Read more
Windows 7: Play Crysis Without a GPU
Microsoft says Windows 7 will run all your 3D games, including Crysis, whether you have a video card or not! Read more
GDC 2006: Dell fires up $10,000 enthusiast PC
Dell today announced the most expensive consumer PC the company has offered in several years. The XPS 600 Renegade comes with any feature a computer enthusiast could desire these days. There's a heavily overclocked dual-core Pentium processor, four graphics processors with 2 GB of memory, a standalone physics processor and a 30" display. Read more
Latest Reviews & Articles
Perfect Notebook Storage: Seven 2.5” 500 GB Drives
We compare the latest 500 GB notebook drives from Fujitsu, Hitachi, Samsung, Seagate, Toshiba and WD. Seagate is first manufacturer to reach 500 GB at 7,200 RPM, but which is really the best drive? We loaded up our updated test system to find out. Read more
Mainstream Graphics Card Roundup
You don’t always need the fastest graphics card around. For somewhere between $135 and $235, you can game like crazy in DirectX 10 without a problem at 1920x1200. We test and compare five graphics cards from this mid-range price segment. Read more
USB 3.0 Ups Peripheral Bandwidth
The new USB 3.0 interface is just about ready. It'll accelerate throughput from the 480 Mbit/s of today's USB 2.0 to 5 Gbit/s, which is important for storage and peripheral devices. But USB 3.0 also introduces power saving options. Read on for more. Read more
Your 64-Bit Check List: Potential Issues You Might See
Hardware and software support for 64-bit operating systems is available, but the full 64-bit reality may still cause you some distress. We created a short summary of things you need to take into account before installing a 64-bit OS for the first time. Read more
All the Reviews & Articles
Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Do you need two 4-pin power connectors for an E-8500?
I have a GIGABYTE GA-EP45-UD3R motherboard and I am about to hook it up this morning.
http://www.newegg.com/Product/Prod [...] 6813128359
I got a question. This motherboard has an 8-pin CPU molex power connector.
If I am just using a 65 Watt E-8500 processor can I do just fine with a single 4-pin molex power connector hooked up to that 8-pin socket?
Or do I need to have the socket completely full?
From what I understand 8 pin is only for a quad core chip.
This is my first Intel build.
Message quoted 1 times
Message edited by Rwayne on 11-03-2008 at 03:28:27 PM
Sponsored Links
One 4 pin 12v connector will do fine. Having two would not provide any additional power than 12 volts, just additional ground.
Reply to badge
You will be ok with a single 4 pin power line to the connector.
Reply to bobbknight
Correct me if I'm wrong, but according to the MB manual, (I have the UD3P, same board 1 more PCIe slot), the 8 pin was only REQUIRED for Extreme Model CPU's. I have a q6600 using only a 4pin and I have no issues with a 3.4ghz overclock on it.
Reply to bosshoss
Bossboss
My MB manual also states that the 8 pin connector is only need for Processors of 125/130 watts or greater. There is no problem in using a 8 pin (altho the 4 pin is fine)
Reply to RetiredChief
- 0 +
Well I used the 8 pin. Any everything turned out alright.
I am kind of disappointed.
I did a build last week with an AMD 64x2 6000 using Windows Vista 64bit and then did this build using an E-8500 Core2Duo on Windows Vista 64bit and I really don't see a huge speed difference.
I was expecting a quantium leap in performance and I don't really see a whole lot of difference.
Message edited by Rwayne on 11-04-2008 at 03:00:12 PM
Reply to Rwayne
- 0 +
It's because the E8500 isn't very good.
I'd recommend sending to to me, and I'll throw it away for you.
------------------------------ GA-X38-DS4 (BIOS F3)||E8400 C2D (3.8GHz)||2*1Gb Crucial Ballistix DDR2-800 4-4-4-12||320Gb WD Caviar||750Gb WD Caviar||Cooler Master Real Power Pro 750W||HD4870 512Mb||HT Omega Striker 7.1
Reply to jay_l_a
This question typically gets asked when the PSU only offers the 4-pin cable, which should be fine for processors up to 100W TDP (or even a bit higher). The 8-pin cable starts to be less optional around 130W TDP, but if you already have a PSU with the 8-pin cable, you might as well use it.
Quote :
Nor will you by subjective impressions of OS performance. The X2 6000+ is plenty fast enough for running the OS and many applications. Not even a QX9770 would make basic computing tasks seem faster than a processor that is already fast enough for them. E8500 will be superior in some application types, but you're going to need objective benchmarks for the rest to "see" any difference.
Review sites are prone to exaggerating just how meaningful performance differences are to the user experience. They might make a big deal about an additional 20 fps but tend to gloss over that nobody is going to see any difference between 200 fps and 220 fps. Its like saying an airline passenger is going to notice the difference between 200 MPH and 220 MPH.
Reply to tcsenter
There are 377 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
