Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Help 2x 9800 gtx sli with 32inch lcd tv
Forum Graphic & Displays : TV/Video Cards - Help 2x 9800 gtx sli with 32inch lcd tv
new custom pc with 2x 9800 gtx hooked up to my 32inch lcd tv using an hdmi cable
started up just fine, after messing around on my desktop for a min or 2 my mouse freezes and i start to see my screen slowly fading out (black)
do i need to change my resolution? nvidia control panel settings?
help plz! >_<
Sponsored Links
What power supply do you have? Wattage, Brand, ect...
Reply to IH8U
apevia 1100w warlock psu
Reply to Boosh3
still need help please! >_<
Reply to Boosh3
Hmmm what brand and type of TV do you have 780i? 1080p? This will determine the max resolution for your TV.
Sounds like you could have a couple issues:
1.) your power supply is made by Apevia which is notorious for low quality PSU's that tend to fail after a couple months....if you dont believe me read the newegg comments associated with your Apevia PSU 4/16 reviews had dead PSU's.
http://www.newegg.com/Product/Prod [...] 6817148037
When it comes to PSU's the quality of the power is more important then the wattage.
2.)your connecting with an HDMI cable .....the only GPU that supports sound from HDMI is the 4870x2. I found this out after hooking my 9800gtx to a 37" Olevia TV. With HDMI cables you get no sound. DVI is the cable connection of preferance for 9800 gtx.
3.)you said it was a new build.....you may not have all the kinks out of it yet. I suggest posting on the Motherboard manufacturers forum maybe they can give you more specific help with your build. ( I recently discovered why my EVGA 780i motherboard was intermitantly failing to recognize my hard drives......turns out the Sata cables included with the motherboard are cheap and can handle being slightly bent).
4.) Could just be your TV. I had a similar issue with CTL 22" LCDs....had to return them cause they would fade to black after 1 minute of using them.....I ended up buying a Viewsonic and havent had any problems since. Does your computer work when you hook it up to a different monitor?
Reply to 3lvis
I just want to comment and say that I noticed that 3lvis posted a very good, detailed and researched reply. It is refreshing to see people as willing to help as this person. And to the OP: It sounds like a power supply issue to me.
------------------------------ Core i7 920 @ 4.0Ghz - Gigabyte UD5 - 12GB Corsair XMS 3 - 2X ATI 58701GB Crossfire- Zalman 850W - X-FI Fatality Gamer Pro - Xigmatek Thor's Hammer - Raptor X 150 - WD Black 1TB OCZ Vertex Turbo 120 GB SSD - Cosmos S Case w/side window + 8X 120mm fans
Reply to annisman
There are 1277 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
