here it is.
this is my first water cooled system
e6850
2 x evga 8800 gtx
4gb ram (4x1gb)
500gb hd
abit in9 x32max
no OC
my system is built into a pc3-724 water cooling case with 3/8ID
the loop
radiator/pump/resivor ->flow meter ->cpu -> splitter 1)drain 2)120mm second raidator -> Splitter to 1/4ID both) to video -> splitter 3/8ID -> back to radiator/pump/resivor
NOW THE PROBLEM.
My pc would not post, the post code was for a bios/chipset error.
i changed the bios chip and now i get a A0
i did some research and found that is chipset damage.
so i have to replace my mobo.
i really do not want this to happen again. so i decided to i needed to water cool the north bridge, south bridge and the voltage regulator, possibily even the ram and hard drive
how should i set up this loop?
i am afraid that the pump might not be able to handle the load
Should i add a second pump?
Should i run a seperate loop?
thank you
e6850
2 x evga 8800 gtx
4gb ram (4x1gb)
500gb hd
abit in9 x32max
no OC
the loop
NOW THE PROBLEM.
thank you
