This problem is very confusing and I'll try and keep it as simple as possible. Basically one of my hard drives lost all of its files or the OS is not recognizing it. They are very important files and I desperately need to get them back.
DESKTOP 1
Drive A: 160GB ATA, Windows XP OS installed, Master
Drive B: 160GB ATA, no OS installed, Slave, Used as a storage Disk
DESKTOP 2
Drive C: 40GB ATA, Windows XP OS installed, Master with no slave
I took the Drive B out and attached it to DESKTOP 2 as a slave.
When I turned DESKTOP 2 on after, it went through a long boot process and it said something about "...reconfiguring your hardware...."
Sensing that there is something wrong, I turned it off and put back Drive B back into DESKTOP 1. Now, Drive B is coming up as a RAW drive (0mb capacity and used space) and it says, "Drive is not formatted. Do you wish to format it now?". HOW CAN I FIX THIS??
What just happened to all my files in Drive B? Please HELP~~~~
Checked BIOS and cables....found nothing wrong....
How can I fix this without using very time consuming and expensive File Recovery progs? There must be a simple way to fix this. Please advise me..thanks..
DESKTOP 1
DESKTOP 2
