i have an asus hd4850 card with an accelero s1 (rev 2) using zalman heatsinks and a 120mm fan attached.
the highest stable overclock i can get is around 680/1050 which is the same with stock cooling. is there something i must do to get 700 or past 700 clock, like pencil modding or something? :\
nope that is not the limit because i use stock cooler on it and mine runs at
690/1118 i don't know how stable it is in games yet but i have one question when i change the fan speed in the thingy and save it the clock speeds reset how do i save those
edit: i am now trying 680/1110 because 690/1118 was not stable
Message edited by hopkiller on 08-24-2008 at 11:59:48 PM
not all cards clock the same exact speed. it will be very close tho. ur oc is fine and i wouldnt push it to hard because the 4850 isnt known to stay cool.
------------------------------intel core 2 quad q6600 @3.2ghz msi p6n diamond (X-FI Extreme sound) 6gig of OCZ+CoRSAIR oc 900mhz Nvidia gtx 260 sli @ 730/1465/1250
Lite-On Blue-ray Western Digital 7200rpm 500gb Antec 500 Earthwatt Window vista 64-bit
Reply to invisik
that is for shure im back at default setting now because it can't cool well it keeps crashing when its overclocked and all im playing on it is teamfortress 2 on it with all hi and AA X4
