This problem has been going on for quite a long time, and only now I could be arsed to ask about it...
I have a 8800GTS 640MB graphics card and it's great and all, but sometimes, when I start a game, after a while into the game it crashes, and I get an error notification at the system tray, saying my graphics card hardware drivers got disconnected and then recovered or something :S
3 things to check gpu temperatures,PSU and the driver= clean install the driver use driver cleaner but more likely it is you card temp make sure you're case has a good air flow and the card fan ,try use riva tuner and check if this happens when you rise the speed of the graphic card're fan to 100%
Message edited by chechnyan on 08-21-2008 at 01:24:19 PM
Typical sign of overheating, the message usually means the card is getting hot, so the the 3D drivers unloaded and the card was halted to prevent damage. Have you removed the card lately and simply blown the dust out of it, and the other fans in your case as well? Also check to make sure the fan is working correctly. Sometimes they do go bad.
Message edited by jitpublisher on 08-21-2008 at 02:42:25 PM
