Tom's Hardware > Forum > Overclocking > Graphics Cards > 4870 Cross fire of Nvidia GTX285
Forum Overclocking : Graphics Cards - 4870 Cross fire of Nvidia GTX285
4870 Cross fire of Nvidia GTX285, your thoughts?
------------------------------ AMD Phenom 2 X4 955 (4.0 GHz|1.36 volts|236 X 17),Gigabyte MA780G-UD3H, 6 GB DDR2 800 RAM (unganged), 2 X 1TB, 1 X 500GB | 22" BenQ Wide Screen monitor, Zalman CNSP cooler
Sponsored Links
4870 cf would be cheaper and perform faster.
Reply to invisik
Would DEFINITELY depend on your resolution, I would not recommend the gtx 285 since the 275 performs only a bit slower and is nearly half the price. So a simple OC would make them the same, But then again the gtx 285 sounds cooler ^^
But, if you are gaming at say, 1680x1050 you would definitely see better results from the Gtx285 but anything over that, the 4870's would win IF you have the 1gb versions. I do not believe 512mb cards are meant to run at 1920x1080 and over.
------------------------------ Core I7 920 @ 3.66ghz | Xfx 4870 1gb Tri-Fire | DFI Lanparty x58 UT | G.Skill Trident 3x2gb @1834mhz | Asus Xonar Dx | Coolermaster Ultimate 1100w | Coolermaster Storm Sniper case | BenQ E2400HD 24inch 1920x1080 | Thermalright TRUE Push/Pull Fan |
Reply to stevensl2
2 X 4870 1GB versions
Reply to lashton
There are 1206 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
