Hi, I'm purchasing an evga 780i mobo http://www.evga.com/articles/385.asp . I was originally going to buy an expensive sound card, but I want to use 3 gtx 280s, and since the 780i's slots are so close together, it wont fit the sound card. Also, 790i doesent sound good, because 8GB of DDR3 is ridiculously expensive.
So, basically, I am wondering 2 things about the onboard sound:
1) How is it? I've been using built in speakers on an LCD with sound card from 03 for years, so I'd like at least a decent jump in quality. Mainly, I want to hear realistic gunfire/footsteps in FPS games.
2) What kind of speakers do I need? Will they need to be 7.1? Or can they be 5.1 or something else? Also, can you recommend any speakers?
Thanks
Thanks
