Hi,
First I am sorry if I have posted this in the wrong place but I didn't know where else to put it. First I will give you my system specs
Q6600 @ 3.6Ghz
Asus P5K-E motherboard
4GB Ram rated to 1066MHz
Windows Vista 64x
Asus Xonar PCI Soundcard
9800 GTX+
Blu-Ray Drive
The issue I am having is quite strange, when playing music or DVDs I get the odd static blip.. It appears to be fairly random, and it is not continuous.. It's a sound similar to a static shock you get from a car body but through the speakers.. It's a static blip sound, quite loud, like a snapping sound.. it's fairly instantaneous in nature and appears to be random... perhaps every minute or two minutes in a movie... sometimes less.. sometimes more..
It's very annoying when you're watching a movie and it keeps blipping every minute or so.. As I said before the sound seems to work perfectly fine, and there is no distortion in the audio at all, but this annoying blip every now and again. It appears to be doing it for all sound; movies, music, games.. Initially I thought it might be a driver issue with the soundcard, so I updated those (originally I was using onboard sound)... this made no difference.. Then I thought it may be a hardware issue with the onboard sound, or perhaps an incompatibility, however since replacing the onboard sound (and of course disabling it) with the Xonar card, it has still made no difference.. I still get this annoying blip..
The movie or game does not pause, it does not stop, the music doesn't pause.
I am at a complete loss as to what is causing this.. I really don't know what the issue is.. Any help or suggestions would be appreciated..
Regards...
Craig
Q6600 @ 3.6Ghz
Windows Vista 64x
9800 GTX+
Blu-Ray Drive
Regards...
Craig
