Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Will this system limit 4870x2 ?
Forum Graphic & Displays : Graphics Cards - Will this system limit 4870x2 ?
Ok this is my system
Q6600 @ 3.2 Ghz
2Gb corsair XMS2 ram
DFI LanParty DK X48-T2RS
corsair 620W psu ( i think this has enough power )
In an previous post i was looking into 2 4850 in xfire. But im now looking into the 4870x2 or the 4850x2 (which would you all recommend). and will my current system limit in any way ?, i will be running on a 42" 1080p HDTV. Also i think my PSU will have enough 12V power but could someone verify please?
Sponsored Links
Probably not. I run a 4870x2 with nearly the same setup as you, and im fine.
But, you could look into upgrading your ram.
Get the 4870x2, you wont regret it.
Reply to Bob_doleee
Should be fine, the one area where you could upgrade is to 4 gb of ram as mentioned above, but you should be fine.
Reply to ThreatDown
There are 1104 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
