Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Where to buy Scythe 140mm Case Fan 1900RPM
Forum Overclocking : Cooler and Heatsinks - Where to buy Scythe 140mm Case Fan 1900RPM
I realize these have been discontinued but if anyone knows where I can find them or anything comparable please let me know! Thanks! I don't want to spend any more than 20 shipped for one of these fans!
------------------------------ Buy my BRAND NEW EVGA 750i SLI Motherboard! $120 shipped OBO! Will consider trades!
http://www.tomshardware.com/forum/ [...] rd-shipped
Sponsored Links
i tried all my sources and came up blank.
Even the classic Matsushita (Panasonic) Panaflo Ultra 120mm x 38mm fan with patented hydro wave sleeve rated at 2,750 rpm, 114.7 cfm, and 45.5 dba is almost impossible to find. It's an oldie but a goodie. Years ago I installed quite a few of those. At the time we didn't care about noise. We just wanted a wind tunnel.
How about the Scythe Ultra Kaze 120mm x 38mm fan rated at 3,000 rpm, 133.6 cfm, and 45.9dba for only $8.95. There are 55 of them available:
http://www.jab-tech.com/Scythe-ULT [...] -3940.html
I know you wanted 140mm fans but what the heck! Somtimes smaller isn't so bad.
Important stuff - The fans I mentioned are 38mm thick instead of the standard 25mm thicks. Make sure you have enough clearance inside the case. I never had a problem with thicker fans.
Reply to JohnnyLucky
Yoosty - Dang! That was the first vendor I checked yesterday evening. Wasn't able to add a fan to the shopping cart. Works okay today.
Those fans use 120mm screw holes. You could probably get a better 120mm fan for less. Like Scythe GT's.
Reply to ShtBrix
There are 1134 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
