Tom's Hardware > Forum > Homebuilt Systems > New System Build > Gaming/Audio System Build
Forum Homebuilt Systems : New System Build - Gaming/Audio System Build
Im building a PC for gaming/audio recording.
I already have a 500gb 7200rpm HDD I'm going to use, so I dont need to buy that.
Here are the specs
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor Model BX80562Q6600
Sunbeam CR-CCTF 120mm "Core Contact Freezer" CPU Cooler
MSI NX8800GT 512M OC GeForce 8800 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
ASUS P5K WS LGA 775 Intel P35 ATX Intel Motherboard
Kingston 2GB 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Desktop Memory Model KVR667D2N5/2G (x2)
HIPER HPU-4M880 880W ATX12V / EPS12V Power Supply
M-AUDIO Delta 44 Professional PCI Interface 4-In/4-Out Audio Card
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case
The total from Newegg.com is $1,043.91
What do you think?
Sponsored Links
you pc doesn't requrie a 880 watt psu. more power to you if you get it just for kicks. but a 600watt should be more then enough.
DDR2800 will give room to overclock the cpu. it's a shame not to overclock a q6600 to at least 3.0Ghz as it takes it so easily.
Unless you really plan to do sli get a intel board with a p35 or p45 chipset. Nvidia chipsets have been sucking lately. Also the radeon 4850 is a better video card. the intel board will let you do those in a dual card senario.
Reply to PsyKhiqZero
What do you have that needs the PCI-X slot of the P5K WS motherboard? Or why did you did choose that motherboard?
Reply to WR2
There are 1032 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
