Tom's Hardware > Forum > Motherboards & Memory > Chipsets & Bios > I reformat and have same problem
Forum Motherboards & Memory : Chipsets & Bios - I reformat and have same problem
i bought a comp little less than 2 years ago
480w power
Asus A8N-E mobo
saphire 1900xt
2g recently put in additional 2g (problems happen b/f and after i installed em)
2 western dig 10,000 rpm hard drives
4200x2 amd dual core
i have bee having multiple problems including:
Blue screen of Death messages like "bad pool caller" and "Machine check exception" and "irq_not_less_or_equal"
this topped off with a random "System boot failure" every now and than on restart. BSoD are random most of the time.
What i tried is reformatting multiple times re-installing the drivers and still same thing. The Ati 1900 has displayed a black screen saying "x1900xt BIOS" once, i reinstalled drivers havnt seen it since. I swapped out x1900xt for another video card and still same error messages same with ram.
These are the mini dump files dont know if they can help i have been loggin them. Any ideas or help would be great.
[url=http://www.4shared.com/dir/10298585/...6/sharing.html][/url]
i am happy to supply any further information...
Sponsored Links
since you just purchased new ram you can either run memtest (recommended)or remove your old ram and see if that stops the crashes. also if you overclock anything make sure everything is set back to stock
Reply to Wgfalcon
There are 1025 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
