If you havent done that already - download Memtest and test the memory. Download prime95 and stress the cpu/check for errors. What memory is it(speed)?
Test your RAM with Memtest and your CPU with Prime95.
Post back your complete system specs and the results of these two tests.
Do NOT post the kernel dump!!
It has no pertinent information and will only serve to annoy us with pages of useless data.
------------------------------If the automobile had followed the same development cycle as the computer, a Rolls-Royce today would cost $100, get a million miles to the gallon, and explode once a year, killing everyone inside.
PSA
Reply to outlw6669
bluescreen usually indicates unstability or corruption and sense your cpu is oc thats the best chance... overheating also will cause it to bs...if both of those are fine check ram and gpu stability
