will these components work together ?
I want to build my own PC, but I don't know how to choose the parts together.
I don't play game, and I'm satisfied with the integrated video card by itself, I Like to stick with Crossfire rather than SLI since I might install a video card later. I'm willing to spend up to 150 on a motherboard which I like it to stay upgradable in the next couple years.
(I have 1 HD and 1 DVD burner and 1 camcorder)
I have no clue if the CPU below work with any of the motherboards or with power supply or with memory
CPU (AMD Athlon 64 X2 600):
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103233
motherboard (which one fit?):
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131331
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131325
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131289
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131280
power supply(which one fit?):
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182016
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182030
and what type of memory should I look for ?
thanks
2 answers Last reply
More about will components work
  1. The first board is definitely the best, as with the first power supply. As far as memory any reputable brand of ddr2-800 will work. I prefer
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
  2. yup as ^he said, just get some corsiar or OCZ ddr2 800, at least 2Gb preferably 4
CPUs Motherboards Product
