Tom's Hardware > Forum > Overclocking > CPUs > Using turbo to hit 4ghz better temps?
Forum Overclocking : CPUs - Using turbo to hit 4ghz better temps?
Hi guys i want to discuss about my i7 overclock using default voltages.
I able to set BLCK to 200 x 20, turbo off and booted up the 4ghz, but as soon as i run prime 95 it would crash within 15 mins reaching a top temp of 75degrees c. Meaning i would probably have to up the voltage to get it stable.
But when i use a BLCK of 190 x 20 AND keep turbo on, when i run prime 95 the multi would hit x21 and i get a effective 4ghz overclock without crashing and temps were better @ 68degrees c
Would keeping the turbo on be a better solution?
Also on the power vs performance review @ http://www.tomshardware.com/review [...] ,2268.html
it is stated that 3.66ghz(183x20 /w no turbo) was the most efficient gain but it they didnt do one with 3.66ghz with turbo..
I was wondering if 3.66ghz + turbo would be more efficient then the one tom's guide recommended?
------------------------------ Core i7 920 d0 3.66+turbo | Corsair H50 Liquid cooler
Foxconn Flamingblade GTI | Gainward GTX 275
3GB OCZ DDR-3 1333 RAM | W.D. 500GB Black Caviar
Sponsored Links
bump
up
my
post
Reply to vinshon
you havea D0 and heat is an issue, are you using the stock cooler?
------------------------------ http://valid.canardpc.com/cache/banner/588938.png
http://www.speedtest.net/result/468703490.png
Reply to shiftstealth
Turbo only overclocks Core 0, which is why your temperatures are lower.
Reply to CompuTronix
i have corsair h50 liquid cooler
Reply to vinshon
There are 1114 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
