Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help Picking Out Motherboard
Hey all, i need help picking out my motherboard.
here are my specs:
CPU - Intel Core 2 Quad Q6600 G0
RAM - OCZ Platinum Revision 2 2GB DDR2
Heatsink - Thermalright TRUE
PSU - SILVERSTONE SST-ST60F 600W
Case - Antec P182
Video Card - ATI Radeon 4850
I will not be using Crossfire, but i will be overclocking my Q6600.
Many people told me to get the P35 chipset, but since the P45 was released. i dont know what to pick now.
Budget will be around maybe 120$
Sponsored Links
Look at the biostar boards, i love mine and they are in your price range- the t series
http://www.newegg.com/Product/Prod [...] me=BIOSTAR
------------------------------ E8500,GA-EP45-UD3R, 8 GIG MUSHKIN, XFX 4890 , ASUS 22", WD 640 X 2, CM 532, CM 650TX
Reply to royalcrown
P45 and although most people don't recommend the Biostar mobos i'm very happy with mine, very easy to use and posted no problem. Alternate choice would be a Gigabytpe P45 DS3L at $108 or an Asus P5Q at $130 (Asus seems to have done a good job on the P45 boards)
Reply to dirtmountain
i've seen recommendations on the Gigabyte P43 board, but I'm not sure how it OCs.
Reply to z999
Biostar TP43HP. P43/45 hits 400fsb with no sweat whatsoever. If you're overclocking a Q6600, you'll be able to reach 3.2ghz, assuming you get a decent chip, without any hassle. This board is cheap, has nice heatpipe cooling, very easy OC features, and it isn't Asus-YAYY!
Reply to effel
There are 985 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
