Now the thing runs a bit hot about 40-45 (it ran hotter with my pos heatsink) celsius at idle, and for the longest time I have been thinking that my crashing issues have been related to heat, although after changing out my heatsink, I don't believe that to be the culprit. It only crashes during heavy CPU load (IE playing Oblivion or CoD4) I could practically set my watch to it crashing in CoD4. I have relentlessly checked to see if it was my Video Card having a conflict with vista, no dice, I have done a fresh install of Vista, no change, I turned on OS plug-n-play and stangely enough I seems to atleast stall it. I am quickly running out of ideas. I have a feeling It could be my PSU but on paper It should (atleast I think) support this rig, the only other thing that it has to power is my DVD drive.
I have been surfing these forums for a while now trying to find an answer to my problem and have now just caved in and decided to make this post.
I was wondering if anyone else has had any similar issues/ideas as to what could be causing this?
I hate to rule out anything, but I currently think my PSU is causing this. I am also probably going to pick up another 120mm fan for it as well, even If I am no longer certain that heat is causing the crashing I am sure I couldn't hurt.
Also While I am here I am noticing that my core temps have a pretty big gap between them presently I have core 1 at 45 degrees and core 2 at 28 degrees. I am not quite as up on dual core processors As I probably should be so is that normal? or should I be looking for a way to correct that? I have been reading about bad temp sensors with this specifc CPU.
If you got this far thanks for reading the mindless rantings of a frustrated mad man, and let me know If you have any ideas for my problem.
Try running with different RAM for awhile. I've had it be the culprit with very similar symptoms to yours. And it's possible a BIOS update could fix any RAM compatibility as well, just incase memtester comes up clean.
Firstly are you overclocking?
Are these Temps from within windows whilst under stress?
Use a windows temp reading program, not bios.
Try to run the vista scoring thing? Tests GFX card and pc, and directx etc...
I THINK, PLUG AND PLAY SHOULD BE ON BEFORE YOU INSTALLED IT NOT AFTER, CAUSE IT WAS INSTALLED WITHOUT PLUG AND PLAY??
You can Check RAM with memtest386, but i doubt thats ur problem unless your overclocking that?
Else, Ebay sells PSU testers cheap, dunno what they are like though.
Also Check with your motherboard manufacturer for BIOS updates for your board
Message edited by sirrell on 08-03-2008 at 08:52:43 AM
Secondly, I am not overclocking anything I am going to try running some tests on my RAM then, also I do not believe I have updated my BIOS for my board yet.
As for the Plug-n-Play thing that one caught me off guard as well I don't mess around in BIOS too much but I can never remember seeing that disabled before...
The Temps are using Hardware Sensors Monitor (freeware), and the ones I post were Idling at desktop
Well, you said it is crashing during a heavy CPU load, but is that only during gaming?
Run Prime95 to get the GPU out of the loop.
Run memtest as another person said.
If memory fails, try swapping them out. IE. Take the one out of the second slot, and test again. If it still fails, put the one you took out back in, and remove from slot A. If it still fails, it would either be bad memory or motherboard.
Check your power output. Is it within specs?
Have you tried to check eventvwr.msc to see if it could lead you in a general direction?
Ok as I said earlier I ran Memtest and it passed, and I ran Prime95's blend stress test and it stabilized at about 59 degrees celsius on core 1 and about 43 degrees celsius on core 2. Seamed fairly stable although I am not sure what I should interpret from that.
I wish I had more information to give you but I cannot thinkl of any other relevant info. Is there a way in vista to create a crash log of some sort so I can just force it to crash again and post that?
Besides that I am starting to give more credence to my PSU theory/ an issue with my card (which has up to date drivers) as those stress tests didn't account for my 9800gtx being in the equation
Also, every time it has crash has been during a game/loading for a game
Message edited by barge on 08-03-2008 at 09:59:52 AM
I dunno about the unevenness of the core temps, but those temps don't seem awful if they are at load 59 is a bit high to me on that core tho, also the stock hsf isn't so bad, mine were 31 and 38 on my 5400 under load. You have a black edition which is basically a higher "bin" chip, it may be running close to it's limits, thus generating more heat vs a chip with more breathing room (afaik anyhow ). maybe reseat your hsf ?
------------------------------E8500,GA-EP45-UD3R, 8 GIG MUSHKIN, XFX 4890 , ASUS 22", WD 640 X 2, CM 532, CM 650TX
Reply to royalcrown
A minimum 500W or greater system power supply (with 12V current rating of 26A)
Above was quoted from the spec page for the 9800gtx...
I would also assum that your problem is the power supply you have. I would think you shoud go with a cosair 600 to 650..
Yeah I am thinking that even if I meet the minium Amperage requirements when the 9800 fires up my 500w can't keep up, probably going to run out and grab a 650 or a 700w with atleast 28 (pref higher) on a 12 volt rail.
Question: If I have 20amps on one 12v rail, and 20 more on another 12v rail will they combine and equal 40 amps, or will I need to find a PSU with more then 28amps on one single 12v then convert two 4pins to make the other 12v rail?
Question: If I have 20amps on is one 12v rail, and 20 more on another 12v rail will they combine and equal 40 amps, or will I need to find a PSU with more then 28amps on one single 12v then convert two 4pins to make the other 12v rail?
No it can't be added like that, not without rewireing and your better off, geting a better one.
But if it says 20 thats not enough.
The 280 gtx requires the 32Amp.
Basically higher AMPS = better cause you can upgrade your card later.
Should say on a sticker on the PSU.
12V - XXAMPS
12V - XXAMPS
ETC
I swapped out that 500w for a Tagan ITZ 700w and it works like a charm and looks awesome, grabbed a 120mm case fan to help out with airflow and it runs much cooler now as well. Hopefully I can go 24 hours without another problem so I can actually play a game on this thing.
While I am here though I do have one (hopefully) final rant...
HOW THE HELL DOES A PSU NOT HAVE ALL OF IT AMPERAGE RATINGS ON THE BOX AND HOW THE **** DOES A MAJOR ELECTRONICS RETAILER (cough frys electronics) NOT HAVE A WAY TO ATLEAST LOOK UP THE SPECS OF SOMETHING THEY CARRY!
but I digress, it may not piss some people off as much as me, but I sell TVs for one of their competitors and its freaking insane how useless their staff is...
anyway thanks for your help guys, since you helped me with some advice I'll help you guys out don't buy VIZIO ever, seriously just trust me on this one.
I have since notice that this products pages are being removed all ova the internet, By the sounds of it you bought a dud model or brand.
Pays to buy a decent PSU!
