What is the normal idle system temperature range for the GA-EP45-UD3P motherboard?
I am using a thermally advantaged case with 2 x 120mm chassis fans, a 140mm fan in the power supply, and the stock CPU cooler included with Intel’s E8500 retail processor.
My system idles at over 40c according to Easy Tune 6. However, Everest provides different readings. I am concerned that there is something wrong – your guidance is appreciated.
Thanks.
Thanks.
