theres absolutely nothing that goes from a video card to a hardrive. That card should have a 6 pin PCI-E power connetor or maybe a 4pin molex on the inside thats it. Externally it should have 1 maybe 2 DVI connetors and S-video for TV hookup. What your asking makes no sense at all. Need better clarified information to help you any further.
You had me scratching my head for a min until I refreshed the page.
Don't plug or unplug anything to/from the hard drives.
Locate a spare plug like the one below (probably will be white).
It can only be inserted one way.
If it gives you resistance, flip it over and try again.
After installing the power, plug your monitor into your cards VGA output.
On your first boot, go into the BIOS and either disable the integrated graphics (preferred) or if you can not, set the shared memory to it's minimum setting.
After booting into windows, cancel all the auto detection driver BS, download and install the drivers from ATI Here.
------------------------------If the automobile had followed the same development cycle as the computer, a Rolls-Royce today would cost $100, get a million miles to the gallon, and explode once a year, killing everyone inside.
PSA
Reply to outlw6669
x1650 uses something like 40 to 50 watts. so even 200w power supply would work just fine provided that the rest of the system isnt hogging power in gigantic amounts...
http://www.atomicmpc.com.au/forums [...] t=9354&p=0
and there is nothing to be connected to a hard drive from a graphics card. Both of them can use similar molex power connectors, but that power is coming from the power supply and going to the devices independently of each other.
Don't worry about the plug you are holding in the picture above.
Just tuck it somewhere out of view and leave it.
In your situation, it is unnecessary.
Looking at the above picture, everything is in it's proper place.
A few things to check.
Is the AGP port filled with dust?
If so, you may not have a good connection to the card.
Is the GPU fully seated in the AGP slot?
It is pretty easy to mount the card with the front or the back slightly raised and not connected.
Remove and remount it just to be sure.
Did you remember to plug the VGA cable into the output from your new card?
Never can be to sure
PSA
Reply to outlw6669
Here's the deal with that power connector. Most older systems (and power supplies) only come with one 4-pin floppy drive power connector. Not all systems have an extra 4 pin molex power connector (for your hard drives). Your graphics card requires a 4-pin floppy drive power connector, so they provided you with a 4-pin molex extension cable with a spliced in 4-pin floppy power connector.
In case you did not have an extra 4-pin molex connector, you would unplug the power connector to the hard drive and plug it into provided cable. You would then connect the 4-pin floppy connector to your graphics card and the 4-pin molex extension back into your hard drive.
My god, (banging my head against the wall) I don't know how in the world he ever got the new graphic card installed in the first place.
Yes, they gave you an adapter that taps into the power supply wiring to your hard drive.
Did you have on-board graphics, or are you replacing an older AGP card?
Message edited by jitpublisher on 08-27-2008 at 02:51:27 PM
If you were using integrated graphics, you will have to go in the bios and disable it and enable PEG using the old connection. Shut down, then connect to the new video card.
------------------------------Google is your friend and Bob's your uncle
Reply to evongugg
