Sorry if this is in the wrong place wasnt sure where to put this.
I am looking to upgrade my video card in my pre built hp a6152n to an ati hd 4850. Now the hp case is a little small and im worried about the card overheating. I already have a larger case. I will also have to upgrade the psu and finding one that would fit in the hp case would be hard as well. So i was wondering if swapping all the hp parts into another case would be a probelm. Also would overclocking the q6600 be possible in a larger case due to not as many heat issues. Just to tell you, everything is crammed pretty tightly in there.
Specifications
Processor: Intel Core 2 Quad Q6600 (2.4 GHz, 1066 MHz front side bus)
Memory: 3GB (Maximum allowed: 8GB (4 x 2 GB) (64-bit OS), 4GB (4 x 1 GB) (32-bit OS))
Hard drive: 400 GB SATA 3G (3.0 Gb/sec) 7200 RPM
Optical Drive: 16X DVD(+/-)R/RW 12X RAM (+/-)R DL LightScribe SATA drive
Modem: 56K bps data/fax modem
Video Graphics: Integrated graphics
Sound/Audio: Integrated High Definition audio
Network (LAN): Integrated 10/100/1000 Base-T networking interface
Operating System: Windows Vista Home Premium
Refurbished: 90 Day Warranty
I/O ports
1 x 15-in-1 card reader
2 x 1394
6 x USB
1 each x Headphone, Microphone, Line-In (Front)
2 x PS2 (keyboard, mouse)
1 x VGA
1 x LAN
1 x SPDIF out (coaxial)
1 x SPDIF in
1 each x Audio (side speaker out, rear speaker out, center speaker out, line-in, line-out, microphone)
Expansion slots
1 x PCI (None available)
1 x PCI Express x16 (One available)
2 x PCI x1 (Two available)
Drive bays
2 x 5.25" (One available)
2 x 3.5" (One available)
1 x Pocket Media Drive (One available
Do You guys think i even need to switch the case in the first place?
The case i have is pretty old but i dont think that would be a problem.
Thanks so much for your help as I am a noob when it comes to fixing computers.
Specifications
I/O ports
2 x 1394
6 x USB
1 x VGA
1 x LAN
1 x SPDIF in
Expansion slots
Drive bays
