Tom's Hardware > Forum > Overclocking > CPUs > Can't reach 3.6 ghz Help
Forum Overclocking : CPUs - Can't reach 3.6 ghz Help
I can't get more than 3.3 ghz from my intel e4500 cooled with ac freezer extreme and p31 gigabyte mobo .what's wrong in my rig ? the power supply ? if i buy a seasonic or a rasurbo i get more room for overclok ?
Sponsored Links
Did you up the voltage already? What settings do you currently have and what other hardware? Memory? I just found out that memory plays a huge role in OCing :). Post your specs and maybe the pros on here can help you.
Reply to era86
Mobo Gigabyte P31 Es3g bios F4
Cpu intel e 4500--> 3 ghz oc'ed
Ram 2x1 gb Adata extreme 800+ micron d9
Cooling Arctic cooling freezer extreme temp: idle: 28, fulll load: 40 celsius
Power supply Delux 450 watt
Video 9600 gt 512 mb ddr3 gainward
Hdd 1 Tb hitachi
My actual settings for 3 ghz stable are:
Cpu Voltage : 1.475 for 333 x 9
ram set 2.1 volt auto timings, ratio 1:1 with bus cpu result a dropdown frequency to 667 mhz
all power savings to off
performance set to standard
Northbridge and fsb volt set to normal
I think that mobo or power supply isn't good enough to get like 3.6 ghz pls get your oppinions
Reply to john_blow_cls
dont worry bout it none of the e4xxx series go past 3.3 just check legion hardwares review, i have a e4600 in my 2nd rig same thing, anything over 3.3 is impossible
Reply to teamlosigp
There are 535 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
