need new power supply
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - need new power supply
I set up a drive bay cabinet and installed 6 Sata drives inside I had an old AT 250 watt I was using for power to 7 drives and multiplexor Looking for a AT 400 watt to replace the no lomger working one I have now but checking ebay and other sites only find them at 250 watts only all the bigger sizes are ATX only and they have a power line going to ther main board which I don't have in my rig
I am using an old Dell Dimension 4300 case with 7 sata drives installed plus a multiplexor the powr supply is an AT 250 watt generic model with 4 output lines which I attached Y connectors to making a total of eight sata power connectors plus a mini connector comnnecting the multiplexor too have no use for an ATX as have no mother board to install a power line connector
where can I buy just a generic AT power supply that will fit standard cases with a hard wired switch both on a cable and on the casing itself rated at 400 watts at least
Sponsored Links
OMG, talk about the things that time forgot. I don't think i can remember the last time i had an AT motherboard.
I'm actually quite confused how you found an AT motherboard that supports 7 sata drives.
Have you contacted Dell to see if they even have any AT power supplies? If not Dell, you could contact Antec or Inwin or any other case manufacturers to see if they have any 400 watt AT power supplies in stock.
AJ
Reply to ajcroteau
i don't even remember what an AT board looks like but ebay does seem to have almost everything there
Reply to Aurora18
I,m lookimg for an AT power supply to power up a vacant dell pc case as the atx needs a mother board before you can get any power from it it only needs power to the seven drives and sata multiplexor only Has no mother board in it at all my AT 250 power supply just burned out and find nothing listed for AT 400 watt power supplys
Reply to chelli
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > need new power supply
There are 1301 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
