I need a new fan for my cpu cooler TRUE ,and I need it to be quiet AND cooling as well, I've been thinking about :
1.Scythe S-flex 1600rpm
2.Scythe GentleTyphoon AP15
3.Enermax Apollish
4.Scythe SlipStream 1200rpm
another question : will it help if I instal 2 fans on TRUE ?
oh and are those 3 fans that I mentioned able to lower/increase the RPM according to the cpu temp. ? I don't wanna change the RPM manually =\
HardOp recommends a pair of ThermalTake Thunderblade A1926 (78cfm, 21dba, 2000rpm, $10).
scythe sff21f (63.7cfm, 28dba, 1600rpm, $13)
scythe sff21e (49cfm, 20.1dba, 1200rpm, $13)
the only enermax i know of that fits is:
enermax enlobal bearing model (44cfm, 17dba, ?rpm, $10)
yes, two is better, one fan pushes into the sync, the other pushes it -- either mount them toward the rear of the case where it exits, or toward the top of the case if you have a blowhole there.
i suggest you spend $13 on a cheap acoustic absorbation mat and stick it onto the inside of your case. it'll cut down the high pitch fan whine extremely well. petrastechshop.com
fan anti-vibration gaskets (usually rubber or silicone) are $3 at jab-tech.com
i honestly cant hear any difference between a case i built with all ~9dba fans and one i built with ~20dba fans. think as long as you stay below ~25dba you should be fine...
Message edited by rkaye on 09-27-2009 at 03:07:50 AM
------------------------------Click my profile to see my current system configuration.
Reply to rkaye
regarding the air circulation , I was thinking about something like this :
plus a fan on the other side of TRUE which moves air to the rear case fan and they're both the same direction.
one important thing though : are those fans that you mentioned that you mentioned able to lower/increase the RPM according to the cpu temp. ? I don't wanna change the RPM manually ...
btw , I guess what's really important is the fa to be quiet at idle , when I'm playing the games it can be noisy because I listen to the game music anyway.
If I install 2 fans on true , will it still be quiet as with 1 fan?
If you go to silentcomputers, they have the math to show that every fan u add around the same frequency adds about 3dB. So 1 fan should about 3db quieter then 2 fans.
I still use my original Thermalright Ultra 120 with a Scythe S-Flex 1600rpm fan. I also installed the same fan on the rear panel.
Adding a second heatsink fan for a push pull effect won't make much difference. Typically the result is a temperature drop of less than one degree. I tried it both ways. It didn't make any difference. Results vary.
Here is a link to a very good web site with useful information about quiet fans:
3.Enermax Apollish
Thank you,
Best Regards,
Eli.
Personally I prefer the Noctua fans. They push a lot of airflow, at very low noise levels.
As to speed adjustable fans, only 4 pin fans do this. Most MB's only have one four pin fan header. A good quiet fan will not be obvious, say, above the noise level of a WD velocoraptor 300GB drive, even when running on high.
A good website for information is silentpcreview.com.
------------------------------Badges? We don' need no stinkin' badges...!
Reply to croc
also...(something i just learned recently) some fans are not intended to be connected to variable-speed headers; usually because they require a min voltage to spin up which might be more voltage than is supplied.
Reply to rkaye
