Try folow this guide EXACTLY as I have written it, I did it almost completely step-by-step! After having a few problems with changing the fan speeds using CCC I finally got it working. There were a few points left out in the guides already created and I decided to make my own that covered everything that I did. I set my fan speed at "40" and my non-load temperature dropped from 78C to 46C!
Anyway, here goes:
1. Open CCC (advanced setup)
2. Select the "ATI Overdrive" tab
- unlock by clicking on the padlock if you have not done this already
3. Untick "Enable ATI Overdrive"
4. Click on "Profiles" at the top of the window and select "Profile Manager"
5.
a. Type in any name under "Enter or select a profile name:". I used "40"
b. Tick all "ATI Radeoean HD 4800 Series [Monitor]" options under the tab Composition -> "the following settings"
c. click on the "+" next to this and tick "ATI Overdrive" only.
d. under the "Activation" tab tick "Desktop shortcut"
e. Click on "Close"
6. Open My Computer *ACTIVATE SHOW HIDDEN FILES (Tools > Folder Options > View)*, (leave CCC open) and go to either:
windows XP >> C:\Documents and Settings\username \Local Settings\Application Data\ATI\ACE\profile created .XML
windows vista >> C:\Users\username\AppData\Local\ATI\ACE\profile created .XML
7. Your profile should be here as a .xml file, right click the file and choose "edit"
Here are the before and after affects of the "fan fix":
I get the feeling however that these cards were just designed to run at +-80C, and that is why the "Automatic" option is set for all cards as this seems to keep the card hovering around that point. I am sure ATI knew what they were doing However, I don't see how running your card 30C can do anything but good for the card...!
