graphics card help
Forum Graphic & Displays : Graphics Cards - graphics card help
Hello.
I just managed to get myself a geforce 7900gtx for £40. however, when i put it in my computer, nothing happens. the system powers on, and the fan spins, but no display. on the box it says 350w minumum, but mines a 400w generic one. due to the size of the fan, i had to tug it out, without undoing the latch, which i thought may have damaged the actual slot, as when i put in my old 6600gt, it managed to display stuff like the bios and post screen, but it was all corrupted, with no readable letters. i dont think i did though because i put in my old X300se and it works fine, apart from not being able to do anything demanding with my pc. any help please would be appreciated. thanks.
Sponsored Links
Usually (in my experience at least) if there's a problem with the graphics card but the system is working correctly, it will beep at you before refusing to boot.
Does the system sound like it's booting up normally? Is there any hard disk activity?
Reply to Anonymous
it doesnt beep or anything, all the stuff just whirls as if it will boot, but doesnt. the red light on the front is on, if thats hard disk activity, but thats on even if the computers fine. and while trying to boot, i can feintly hear a kind of irregular chiming sound.
Reply to Anonymous
hmm.. no beep and sounding like it's booting normally would suggest to me that everything's working, but it could be a problem either with the connectors on the card that lead to the monitor, or something similar wrong on the output part of the card that is causing no display but not registering as a fault on the card (this is just an educated guess here)
Try removing the cable from the back of the graphics card and ensure there are no bent pins
Reply to Anonymous
Either your PSU can't handle the load (just because it says 400w doesn't mean it has the ability to consistently handle high load) or the card is dead.
Did you get the card from a friend, Ebay, Craigslist...etc?
If you have someone that has a working system, ask them if they can test it out for you. If you discover the card is dead, see if you can find out if it was registered and valid for RMA.
------------------------------ The Pastafarian belief of heaven stresses that it contains beer volcanoes and a stripper factory. Hell is oddly similar, except that the beer is stale, and the strippers have VD
Reply to rubix_1011
You did plug the PSU to the vid card?
Reply to rdb
to weetobix: i changed the dvi to vga adaptor and it still doesnt work, if thats what you meant, and all the holes look fine. are you talking about the power cable at the back of the graphics card? its like V shaped, two of the connectors are the same as the power ones that go into CD drives, and the other into the back of the card.
to rubix_1011: thats what i was thinking, but the guy i got it off said he was running it on a 480w psu OC'd with 5 HDD's and it was fine, and my computer's got like 1. I got the card off gumtree.com, which is similar to craigslist. I have a friend i could ask to check, which i may do, and if it doesnt work ill try and return it to the guy who sold it to me, as he said it works fine.
to rbd: yeah i did, ive tried it with different power cables and combinations and it still sounds like its stuck at boot.
Reply to Anonymous
I would check the 12V rail rating on the PSU. Generic PSUs have a tendency to have weak 12V rails, which nearly every power hungry PC component runs off of.
Reply to TurdBurglar
im not really sure about reading the psu rating thing as i havent done that before, but i think for 12v it is 17A, the graphics card box says 350 minumum with 12v current rating at 20A. is that most likely to be the problem, meaning the actual card is fine, and i just need a new psu?
Reply to Anonymous
I would guess that to be the problem. You can either try the card in a different computer with a beefier PSU or swap a nice PSU in your PC. You can get a very nice one with 33A on the 12V rail for $50. I'm running a Q6600 OC'd to 3.2ghz and an OC'd 8800GT on mine rock solid.
http://www.newegg.com/Product/Prod [...] %20corsair
------------------------------ Q6600 @ 3.2ghz w/ Tuniq Tower 120 | Gigabyte P35-DS3L |
2gb Super Talent PC6400 | BFG 8800GT OC 512mb (740/1854/1980) w/ Accelero S1 Turbo |
Corsair 450VX PSU | Cooler Master Elite 330 Case | Windows XP Pro | 3dMark06 14,716
ok, thanks. I dont really want to spend too much on a PSU as my systems fairly old (amd 64 3200 939, 1gb ram, 1 HDD) so it wont need too beefy a power supply, and im a student, so preferably in the realm of $20/$30. Glad to know its the psu rather than the card though.
However i was also wondering why my 6600gt no longer works. it was working fine before i put the 7900gtx in, however as i couldnt reach the latch to remove the card, i yanked it out. could this of caused damage to the PCI-E slot, m x300se works in it, so it might be due to the weight.
Reply to Anonymous
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > graphics card help
There are 1133 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
