Tom's Hardware > Forum > Overclocking > General Discussions > 2 Memories running at different clock speed
Forum Overclocking : General Discussions - 2 Memories running at different clock speed
heyy,
I've got two different memory manufacturer in my case. One is a OCZ platium edition with 4-5-4-15 and the other is a Kingston ValueRam running at 5-5-5-18. Does it matter that these run differently even as though both run @ 800MHz?!
Message quoted 1 times
Message edited by thrunthru on 09-27-2009 at 08:46:25 PM
Sponsored Links
If they are compatible together (I say If), they will can only run as fast as the slowest stick is capable of running.
------------------------------ Case :Antec SLK 1650B /PC Power&Cooling Silencer 610w /ASUS M3A79-T DeLuxe /AMD 940 PII @3830 1.4625v/Zalman 9700 LED /OCZ Reaper 8500 4x1 @1100 4-5-5-15 /EVGA 260 core 55nm 648/1404/1044 / Creative X-Fi Elite Pro - Logitech Z-5500 /Mon:
Reply to unclefester
thrunthru wrote :
heyy,
Well my friend I would not reccomend that to any one. If it does work on your M/BD they will usually default to the slower timed stick of ram as opposed to OC'n the slower stick to match the faster timings.
More importantly probably thou is using different sticks like that can give you stability issues resulting from corruption of your OP/SYS files.
I would reccomend that you use a matched set of ram assuming your M/BD supports dual channel mode ( as most do now adays ) or not just for the stabilty issues involved.
Good luck
Reply to arthurh
Good luck
Oh man thanks for the help, I'll be having anyways another OCZ plantium edition this week or so and that kingston's, they'll be in the other computer. :D
Reply to thrunthru
There are 1114 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
