Tom's Hardware > Forum > CPU & Components > Sound Cards > Sound Card Question
Sound Card Question
Forum CPU & Components : Sound Cards - Sound Card Question
I have a Asus P5B (vanilla) and I have recently recovered a Sound Blaster Audigy LS (SB0310) from another system.
Now - My gut feeling is that the Sound Card will be better than the MB sound - but is this card sufficiently ancient as not to be of any real benefit? Is there a better card that is miles ahead of either of these?
I only use 2 speakers + a sub - so 7.1 isn't much of a concern to me in any scenario.
Thank you for your input.
- Cheers
------------------------------ CPU-E6600 - AC Freezer Pro 7- ASUS P5B MB
2GB Corsair TWIN2X2048-6400C4 - XFX 8800GTS
Antec P180B case - FSPGroup FX600-GLN 600W PS
Sponsored Links
I would say if you dont have the greatest speakers then just stick with a cheaper soundblaster card. if you do plan on upgrading your speakers then i would suggest the x-fi xtreme gamer fatal1ty series. They can be found from anywhere from $75-$135 dollars. (i usually buy from newegg.com but found a great deal at bestbuy for that $75 price range)
Reply to crowheart27us
There are 631 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
