Tom's Hardware > Forum > Overclocking > Motherboards > [Solved] Phenom II X4 stuck at 800Mhz HELP!
Forum Overclocking : Motherboards - [Solved] Phenom II X4 stuck at 800Mhz HELP!
Best answer from Crazyloon.
I have a Bio star TA790GX 128M motherboard.
AMD Phenom II X4 945 processor (stuck at 800Mhz should be default 3Ghz)
I've downloaded the latest bios from Biostar's website (78DEA525.BST)
I've tried separately clocking through bios and the AMD Overdrive tool. I've successfully managed to crank it up to 2Ghz/core without a crash, however when I look at system info (windows 7) it says something like 940Mhz. (have not been able to replicate or even clock at 2Ghz for a while now)
How can I get my processor to run at the correct speed??
Well, here's the solution:
Although it clearly says: "Supported Socket AM3 processors AMD Phenom II X4 / Phenom II X3 / Phenom II X2 processor"
^ http://www.biostar-usa.com/app/en- [...] p?S_ID=377 ^
The truth is, Phenom II X4 processors will NOT work correctly with this board! Maybe there will be an update that will allow it in the future.
I went to a friends house and swapped him my Phenom II X4 for his Phenom II X3. The X3 works briliantly with the TA790GX 128M and my X4 works brilliantly with his TA790GX A3+
Sponsored Links
Disable the Cool'n'Quiet on the BIOS.
------------------------------ If you like my answer, select me as the best answer.
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.". Albert Einstein.
Reply to saint19
I have tried disabling cool and quiet as well, do you think maybe the processor is just bad?
Reply to Crazyloon
Have you run CPU-Z to see what the volatge the CPU is running at?
Have you tried disabling Cool `n` Quiet in the BIOS and disable C1E power management mode? These all work with the CPU and the motherboard to lower CPU power consumption by reducing the CPU frequency and voltage when the CPU is not under load.
If that dont work then its old-skool hardware testing time - suspect CPU into known good board and vice-versa. Then once you found the faulty part, its RMA city!
Reply to tricky_uk
^try with another mobo, I don't know nothing about Bio Star. If with another mobo works in the same way, the problem is the CPU if isn't is the mobo.
Reply to saint19
http://i33.tinypic.com/ety1qw.png
Check this out does that look right? I'm Googling the default voltage, maybe it needs to be higher?
Reply to Crazyloon
A little diferent from my processor (955), but in my CPU the voltage is 1.35V, the multiplier is 16x and th HT link is 2000MHz....i think that the configuration of both procesor in Voltage and HT could be the same....and the muiltiplier could be 14x or 15x for the 3GHz stock of your CPU.
Reply to saint19
I just tried to increase the Core Voltage to 1.225 or 1.25 w/e it was and tried to change the multiplier to X8 doubling from X4 it's at right now (all in BIOS) and it crashed on me, had to jump cmos 8X is the lowest it will let me go maybe i'll try a lower voltage
Reply to Crazyloon
800mhz @ 1.0v-ish is the bottom steping of the cool `n` quiet feature of the PIIs.
Its either a faulty CPU, pretty rare to be honest as its being identified as the correct part and model number in CPU-Z and you have the latest BIOS or its a faulty mobo.
What CPU did you have before the PII and did it work fine or is this brand new build?
Also, what PSU and VGA card in your system, as the PSU may not be enough as the 945 is 125W part.
Reply to tricky_uk
^That is probably right...It is the bottom step of cool `n` quiet...
That's normally what I get when cool `n` quiet is turned on...
You should try it in a different mobo...
Reply to videl
yeah this is a new build I got Sapphire brand 4850 500W power supply I actually sent the processor back today i'll try it again in a week when it returns.
You say that the 1.05V i'm at is because of stepping off CnQ, should it auto fix when I turn CnQ off?
If it returns and I've got the same problem, just try to increase voltage in small increments while adjusting the multiplier too?
What would a normal PII X4 have the cores' voltage at with 200Mhz X15 multi?
I wonder if I should to send the Mobo back too, before time runs out for the RMA, just in case...
Anyone know of this similar problem with Biostar boards, or the TA790GX 128M in general?
Reply to Crazyloon
If you disable CnQ in the BIOS then it should run at top speed all the time.
Top speed is 3000MHz, which is 200MHz internal FSB at a multiplier of 15 at either 1.5V or 1.42V depending if you go the 125W or 95W version of the chip.
CPU details from here - http://products.amd.com/en-gb/Desk [...] 588&id=534
TBH I would have RMAed the mobo first anyway, as if you have an AMD reatil boxed CPU it has 3 year warranty direct with AMD and you can do an easy online request in a few days. Rant on/ Ive done this myself a few times and I will never, ever buy another TRAY/OEM processor again after the hassle of trying to send that back to the place of purchase for warranty! I always reccomend buying the full retail boxed version of any kit just for that reason alone, its worth the extra £10-15 every time /rant off.
The worst case now is that your new CPU has the same issue as the old one and your mobo warranty runs out.
Reply to tricky_uk
Did you try running a CPU intensive application to see if the core clock increases? If you run 4 instances of Prime95 you should see the core clock reach its normal settings.
I've never had an issue like that so it would be good to know what the problem actually was. Keep us updated.
Good luck.
------------------------------ Gigabyte EP45-UD3P|e8500 @4.0|2x 4850s 512MB Crossfire|Audigy 2ZS|2x2GB Corsair XMS2 DDR2-800|WD6401AALS|
HannsG 28" HG281D|Antec 650W TruePowerTrio|G9 Laser Mouse|G15 Keyboard|
Reply to m3d
I know you have a totaly different system and it may not help, but I had issues with a BIOS on my board running at lower frequencies than spec'd, even after manually changing them and I help a lady on here once with a different brand chipset, running an AMD proc, doing the same thing. Both issues were resolved with a BIOS update.
Reply to inglburt
Ok, I still can not for the life of me figure this out. I got my processor back, put it in, no go. The mobo didn't work at all after that. I sent the mobo back for repairs, they sent me a new board, and I have put my computer back together. However I still have a problem with each core only running at 800mhz. I'm wondering if maybe it just says it is running at 800mhz and actually is running faster. I was able to run Fall Out 3 at ultra high quality, aswell as CoD 5 WaW at full quality. I mean, if I can play the games I wish at full quality I guess there is really no reason for me to complain, but I feel like I got bent over if I'm only getting less then 1/3 the power I paid for.
Reply to Crazyloon
I'm thinking that possibly the combination of your parts are not the best...maybe if you chose another motherboard it wouldn't say that...
Reply to videl
Best answer
Reply to Crazyloon
That's what I've been guessing...It's good that this problem is now solved... ;)
Reply to videl
There are 1226 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 DustenH won the Uniformed badge
  • 01:00 bew1075k won the Uniformed badge
  • 01:00 Parasitic won the Uniformed badge
  • 01:00 X3no won the Uniformed badge
  • 01:00 Siq won the Uniformed badge
  • 01:00 wayspooled won the Uniformed badge
  • 01:00 chris62 won the Freshman badge
  • 01:00 Tattysnuc won the Freshman badge
  • 01:00 gamerk316 won the Freshman badge
  • 05:23 jsc won the Overclocking badge
