Ok, my problem is that onece i set up my computer up my memory timeings are at 8-8-8-18, that was my "optimal" settings under my Bios, i had to manualy set it to 6-6-6-16 anyhtign under that and my system will not POST like is should, any help here?
Timings Dram Frequency 398.1Mhz FSB: DRAM 14:13(unlinked in bios) CAS# Latency (CL) 5.0 clocks RAS# to CAS# delay (tRCD) 5 clocks RAS# to Precharge (tRP 5 clocks Cycle time (tRAS) 18 clocks Bank cycle time (tRC) 23 clocks Command Rate (CR) 2T
Message edited by x_2fast4u_x on 11-16-2008 at 10:08:23 PM
------------------------------Q9650@ 4.05ghz
GTX285 black edition
2x2gb G.kill 1200mhz
780i SLI FTW
Reply to x_2fast4u_x
You might try running 2x1 at 5-5-5-18 and if you can run stable,tighten them 4-4-4-14.Then put 2 back in.
I see your at 61% OC, if the first step doesn't work you may want to half your OC, then start bringing it up a little at a time.
Sorry I don't know Intel very well, I'm running on a AMD platform.So I may no be much help.
