I have just bought the Radeon 4870x2 from HIS! It's an awesome graphic card, but the temperature is a little high. It's about 60'C in idle and 80-85'C when I play a game. So I'm woundering, how do I increase the fan speed? I think I read somewhere that the default speed is 25%, so setting it to 45-50% should do the trick!
But I've heard that if you change the fan speed manualy, it will always run at that speed. But can you fix so it runs at ATLEAST 45-50% or MORE if needed. So it changes that it self, but never goes under the minimum %? Hope you understand what I mean.
If I need to download any program or do some changes in a program I already have, please explain exactly how.
The latest version of Rivatuner may work for you. You may find it, and detailed instructions on how to set it up, at www.guru3d.com.
------------------------------There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
