Built a new system with ASUS M4A89GTD PRO/USB3 MB, Phenom II X6 CPU, and 4 Gb DDR3 memory. Had problems running XP - need to run XP because of expensive legacy peripherals and no Win 7 drivers. The following is a summary of many installations of XP (and Win 7 on separate, fresh HD).
Windows XP ran EXTREMELY slow - 3 frames per second (measured). A fresh reinstall with different and known to be good GeForce card gave same results - 3 frames /s. Totally useless! To checkout system, on a separate HD I installed Windows 7 Pro. Using this as the only drive , Windows 7 ran at 660 frames per second! Why the extreme difference?
Additional info.: Win XP ran perfectly normal with internal, (on MB) GPU!
No help from ASUS - hope somebody has an answer for me, PLEASE?!
